RICOH MP4001 (Not detected, USB CARD READERS)
  • omorales
    • Mar 2015
    • 86
    Hello friends, I wonder if Someone Special to had this problem, connect connected without our team a message that the reader is not connected.
    Are enabled (USB host), it was another reader tests without success.
    The team has Pepercut installed.
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: RICOH MP4001 (Not detected, USB CARD READERS)
    I beg you pardon? What are you trying to say?
      • 37529
      Java VM card is required. The 4001/5001 comes with the VM card as standard but check that it is installed and functioning properly. The card reader will most like require an App in order to work. PaperCut is your best place to contact to make sure that you have everything needed, that it is supported on this model and that it is installed correctly.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        with papercut there is a config file that has to be edited with the ip of the server and the device and then zipped and loaded to the mfp extended features before papercut and the machine will recognize the card reader. BTDT................
        Mystic Crystal Revelations
          • 37529
          Sounds to me like that was not done correctly.
          I've not worked with PaperCut but knew it was a VM app.
          • Tonerbomb
            • Feb 2005
            • 2589
            It is a VM app and it does require java to be running............ Had a sales rep send an mp 401 to a collage to eval PC, the standard 401 does not have java and requires a HDD and Memory plus the VM card to run java................................
            • omorales
              • Mar 2015
              • 86
              The papercut, and java is working well.
              As dicia them the message I have attached image.
              • heeks
                • Jun 2012
                • 19
                Did you try to disable/enable usb in sp mode ?
                I had to do this once for a card reader ( i even changed it thinking it was broken )
                • Tonerbomb
                  • Feb 2005
                  • 2589
                  do you have sp 5113 set correctly? and the external charge device set up in UT? and did you chande the Heap and stack sizes?
