MP 7502 Noise
  • JonJames
    • Feb 2014
    • 19
    MP 7502 Noise
    Hi all, hope someone can help,
    i visited a site today 1.4m copies on a 7502, initial call was for poor copy quality, look like drum so i too it out to confirm, once confirmed put it all back into the machine,
    machine ran about 50 copies ok, then we get a noise, its like a drive noise or gears not meshed. took drum dev out again and re-fitted still the same,
    i can replicate the noise if i run main motor in output mode,
    Any suggestions ? as yet i havent looked at the drum motor, had to leave site
    thanks
  • vargue
    • Oct 2011
    • 404
    Re: MP 7502 Noise
    first yo must take off drum first and try . then tank . i met this before it was fuser unit .make this noise . web roller don't turn .it was mp7500 and after changing web motor roller with some silicon grease on web roller noise is gone and machine worked perfect.web roller with high temperature become useless . it's need some silicon grease .
    • TonerMunkeh
      Professional Moron
      • 3865
      Re: MP 7502 Noise
      The toner recycling tube on the front of the PCU has two black gears at the bottom. They fail quite regularly on all models of the Martini.
      Hit it.
      • Counsel
        • Aug 2011
        • 529
        Re: MP 7502 Noise
        One of the common noises i get with this PCU setup is on the toner hopper. There is a shaft/auger on top of the toner hopper that runs under the toner separation unit at the front end the shaft has a black gear smaller then a dime and a E clip, you get toner build up in the bushing and it will screech like a goose call. If your hearing grinding though i would inspect the repairs you made, make sure the drum was powdered and the blade is powdered. check your gears on the pcu and toner hopper units.
        • JonJames
          • Feb 2014
          • 19
          Re: MP 7502 Noise
          Thanks all for your suggestions, im going back to site on Tuesday probbly with new drum / dev and will investigate further then, will report back what the issue was (if i find it!)
          • mohan
            • Oct 2013
            • 86
            Re: MP 7502 Noise
            thanks
            Check the toner recycling gears on the front of the drum (one that drives the spiral) is meshing properly.
            • JonJames
              • Feb 2014
              • 19
              Re: MP 7502 Noise
              Thanks for all your help, it was indeed the gears on the recycling unit.
              Sorted!
              • sturmtrooper
                Copier Combobulator
                • May 2016
                • 587
                Re: MP 7502 Noise
                I just replaced both of those on a 7502 with less than 12k on it because waste toner had hardened and seized everything. Broke the waste toner transport coil in the drum unit too.
                • jfbar1
                  • 53
                  Re: MP 7502 Noise
                  Definitely the web motor. Had several of these series (brand NEW machines actually), lock up and when enough toner gets jammed in the web and hot roller, makes grinding type noise from extra drag.
                    • 37514
                    Re: MP 7502 Noise
                    I have had new gears start jumping teeth in less than two weeks. Solution is the replace the entire assembly, PN B247 2395 Toner Recycling Ass'y.
                    • sturmtrooper
                      Copier Combobulator
                      • May 2016
                      • 587
                      Re: MP 7502 Noise
                      I replaced the whole assembly with one from a parts 5500 at the shop.
