Ricoh Aficio MP C2051 - scanner to folder
  • PauloPG
    • Apr 2025
    Hi everyone,
    Need some help!!!!!
    How can i scan to folder in this printer nothing work
    i have creted a folder "Scanner" full shared, my PC is on the net, but the printer don't recognise the way to this folder, i see my pc but not the folder.
    i use windows 10 but it was working in win7
    can anyone help me!!
    thanks for the help!!
  • keithxxiii
    Just a tech
    • Nov 2014
    • 469
    Re: Ricoh Aficio MP C2051 - scanner to folder
    Update your firmwares.
    Aye! Cut the crap
    • PauloPG
      Tks,
      i have tried......how can i do that
      • keithxxiii
        Just a tech
        • Nov 2014
        • 469
        upgrade via WIM or upgrade thru SD Card or if you have an @remote services running on it, upgrade remotely then come back the next day to test it.
        firmwares can be downloaded thru my-ricoh
        Aye! Cut the crap
        • Chicko
          • Sep 2015
          • 36
          I had a similar problem with a Ricoh MP171. The solution was 2 parts
          1) Upgrade firmware on the machine using SD Card.
          2) Create on the windows 10 computer another profile with full admin rights, i.e. User Name and Password and input this in the setting for folder authentication.
          That with the correct folder path will get you scanning again.
          • sandmanmac
            • 3969
            Originally posted by PauloPG
            Tks,
            Call a tech
            Obviously this is an end user that doesn't have that type of access
            • PauloPG
              Originally posted by sandmanmac
              Call a tech
              • Harmanoff
                It wouldn't work on a Ricoh Machine we were getting all setup last Friday unless it had a username AND password...so yea id say that is a good suggestion
                • sturmtrooper
                  Copier Combobulator
                  • May 2016
                  • 589
                  Try setting your network settings to allow less than 128bit encryption.
