White shade on copies on black only, not really on prints.
  • scottyzinsd
    • May 2016
    • 11
    [CQ] White shade on copies on black only, not really on prints.
    I am getting a white shade on copies, not really on prints. It only happens on the black portion. I attached a print out of the color sheet, which shows the missing black on the side. I also attached a color calibration that failed, not sure if it because of the missing black portion. I replaced the black developer. it's a MP C3503 aficio.Copy quality.pdf
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: White shade on copies on black only, not really on prints.
    Developer or laser. Clean the laser slit glasses then ACC it. If after cleaning the laser glasses you still have the defect, replace the black dev unit. What are the counters on the machine?
    Hit it.
      • 37550
      You need to clean the laser shield glass. If that does not correct it, then you have a dirty doctor blade on the development unit. You may have to replace the complete development unit, not just the developer. On other potential problem is that you have gotten dust or toner inside the laser unit and on the final mirror for the black laser.
      • scottyzinsd
        • May 2016
        • 11
        I replaced the developer. I cleaned the 3 mirrors/ glass. If they are dirty would it still just show on black only? Shouldn't it show on all colors? Counter not high, about 150k.
          • 37550
          TonerMunkeh was referring to the laser shield glass.
          • scottyzinsd
            • May 2016
            • 11
            the laser unit? in the body and not under the exposure glass. sorry I am very new at this.
            • mikadonovan
              • May 2008
              • 2931
              The blue stick in the front door. The cleaning slots are below the PCU's.
              NEVER ASSUME ANYTHING
              • scottyzinsd
                • May 2016
                • 11
                It was the glass shields. I used that blue stick. it did nothing to solve it. I needed to pull the laser unit out and clean the glass by hand.
                Thanks everyone.
