Mp3353
  • Lanierman
    • Jun 2015
    • 9
    Mp3353
    Dog ear on duplex and jam in bridge unit
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Mp3353
    Duplex RTB.pdf
    Hit it.
    • Lanierman
      • Jun 2015
      • 9
      Re: Mp3353
      Originally posted by TonerMunkeh
      [ATTACH]33328[/ATTACH]
      Done the rtb but it still jam after exit unit
      • TonerMunkeh
        Professional Moron
        • 3865
        Re: Mp3353
        Does it do with with all paper types and all directions of feed? IF you put a small tippex mark on the exit rollers do they visibly turn? Has the small actuator on the duplex gate pawl been broken off?
        Hit it.
        • Lanierman
          • Jun 2015
          • 9
          Re: Mp3353
          I need to check with other paper
          the actuator have been change and tested on another machine
          once the bridge unit is out there is no dog ear or jam on duplex
            • 37532
            Re: Mp3353
            Can you tell us what the jam code is?
            • HDSB
              Field Tech
              • Feb 2013
              • 64
              Re: Mp3353
              file down the plastic so the inverter junction gate opens wider - problem solved!
              • Lanierman
                • Jun 2015
                • 9
                Re: Mp3353
                That a good idea will try
                • Lanierman
                  • Jun 2015
                  • 9
                  Re: Mp3353
                  Jam code is 21 and 22 bridge junction
                  • Lanierman
                    • Jun 2015
                    • 9
                    Re: Mp3353
                    Have replace exit and reverse junction gate but it still cause dog ear
                    and even the gate pawl as per bulletin
                    the machine is fine without the bridge unit
