MPC6502 SC515-002 Duplex unit error
  • barber782
    • Aug 2011
    • 285
    [Error Code] MPC6502 SC515-002 Duplex unit error
    Hi All,
    I have an on going fault with a RICOH MPC6502 with an error code of SC515-002 which is related to the duplex unit. Its seems to jam halfway through a duplex job.
    So far Iv cleaned through the duplex unit free of any spilt toner or paper dust. Iv added the modifed black mylar guides to the exit unit and duplex.
    any help would be much appriciated.
  • techmann
    • May 2016
    • 41
    Re: MPC6502 SC515-002 Duplex unit error
    I have seen the jogger end fences in the duplex unit stick, causing them to not move to home position. I have also had the actual jogger motor go bad.
    • slot
      • Jul 2008
      • 341
      I have had a mpc6502 that kept having dplex sc in the end it turned out to be a small piece of paper in one of the 2 black connectors on the dplex I took a photo on my phone to see it to sav e removing the connector firs it was right at the back of the connector
      • barber782
        • Aug 2011
        • 285
        Im leaning towards the jogger fence as there is a bulletin on ricoh tier 2 site regarding this error code. Will have a play and let people know the results.
        • kannuki2
          • Feb 2012
          • 398
          • barber782
            • Aug 2011
            • 285
            Haven't returned to customers yet as schools are on holiday. Will post the outcome once I've been
            Sent from my GT-I9505 using Tapatalk
            • Bucky
              • Dec 2015
              • 30
              Did you find a fix for the SC515-02 error code. I have a 6502 that is having the same problem. My machine is running 35K per month now has 2.0 million on it. The code pops up randomly.
              • Gamut
                • Jul 2008
                • 216
                The stepper motor (D1364544) gets toner/dev dropped on it and goes bad.
                This motor controls right hand rollers movement.
                I had to go back a while later to replace the left hand side (sc515-01) as well, so replace both!
                • Bucky
                  • Dec 2015
                  • 30
                  Thanks for the quick reply. I already have the motor on order. Should be in next week sometime. The customer is closed for he Holidays and won't reopen until Jan 3rd. So I have plenty of time to get it in. Merry Christmas to all.
