Copier does not turn on
  • Ardillon Mc Bite
    • Aug 2025
    [Electrical] Copier does not turn on
    Hi,
    I just receive a Lanier/Ricoh copier LD430C from an Imaging Center. It was working, but once I plug it at home, it does not. Will it cost a lot to fix this problem?
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: Copier does not turn on
    Originally posted by Ardillon Mc Bite
    Hi,
    It depends on the actual problem. It's like telling a mechanic your car doesn't start. There could be several reasons.
    • sandmanmac
      • 3981
      Hi,
      I'd like to answer that, but unfortunately my crystal ball is in for service too.
      • sturmtrooper
        Copier Combobulator
        • May 2016
        • 587
        For now make sure that the socket you are plugging the machine into works and is able to provide enough power for the machine. Some machines requires 15 amps some 20 amps. Some (in the US) are 110v and some very large units are 220v.
        Check the power cable for cracks, cuts, etc. If it is damaged a cable like this https://amzn.com/B0027JRMD0 should suffice. Assuming you have a 15 amp machine.
        Also, maybe you should call the people you just bought it from and inquire with them?
        • DRichard
          • May 2008
          • 482
          Hi,
          YES
          "Enjoy every sandwich."
          -- Warren Zevon
          • Ardillon Mc Bite
            Thank you!
            It's a very heavy machine. I realize that there is a split between the cord and the plug. I will buy another one.
            Very Respectfully,
            Ardillon Mc Bite
            • sturmtrooper
              Copier Combobulator
              • May 2016
              • 587
              Thank you!
              Very Respectfully,
              Ardillon Mc Bite
              The delivery guys probably ran the machine over it's cord.
              Just make sure you get one rated to carry the amount of current the machine will draw. Copiers suck down a lot of power when running and if you don't want to melt the cable and possibly burn your house down you need the right one. There should be a sticker in the area of the power cable socket with an amp rating.
