Good for a laugh. Bone head mistake
  • Qball
    • Jun 2013
    • 127
    [Misc] Good for a laugh. Bone head mistake
    So I'm going to a MP C305 and I have to replace the bypass separation pad. I get to the account I take the machine apart to replace the pad which I do without incident. I put the machine back together and then I close the right door and then I went to open it back up and it wouldn't open. I couldn't figure out what I had done to make this happen and I tried to not force the door open but could not get this thing to cooperate with me. I ended up getting frustrated I forced the door open and I broke the duplex frame and the fuser release arm on the front side. When this happened, I saw what I had done to cause this. I neglected to replace the strap that goes from the release handle to the actual latch. Frustrated, I ordered the parts I needed. I returned a few days later with the parts and I replaced the duplex frame and the future release arm and I told myself to not forget the strap. I went into autopilot mode and reassembled everything. I got done, I then close the door and to my horror I FORGOT THE DAMN STRAP AGAIN!!!!!! Needless to say, I was beside myself! There was no way I was going to break this door again. I was hunting around trying to figure out what to do about this. What I did was I was able to get to the bottom hinges of the door from underneath the machine somehow get the e-clips off of them and force the hinge pins out of the hinges. That gave me a little bit of play in the door. I was able to get the top of the door out and grab the bottom edge of the door and twisted in a counterclockwise direction and the latch let go, much to my relief. I then promptly reattached the strap put the hinges back together, verified it's operation and then got the hell out of there!
    Not one of my finest days my 20-plus years of doing this!
    Sent from my SM-G900V using Tapatalk
  • qbert69
    • Mar 2013
    • 1152
    Re: Good for a laugh. Bone head mistake
    Gotta Love Those "Note-to-Self" Moments!!!
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • NeoMatrix
      Senior Tech.
      • 3513
      Welcome to the human race, planet earth, 3rd rock from the sun...
      I've had the odd auto-pilot moment.
      Not as memorable as yours by the looks.
      I've used the self Post-it-Note on occasions:
      Dear self.
      Yes self, remind me to boot self up the rear-end when I get home.
      Okay self...
      Done!...(ouch!)...
        • 23009
        What's truly impressive is that you managed to make the same stupid mistake TWICE, exactly the same way! Congratulations on finding the sense of humor to share this with us.
        Someday I'll tell you how I got my arm stuck in a FS532 finisher. Only once, but once was enough for anybody's lifetime. =^..^=
        • Qball
          • Jun 2013
          • 127
          Well, you have to be able to laugh at yourself. Otherwise you'll turn into a crabby SOB!
          • NeoMatrix
            Senior Tech.
            • 3513
            Oh com'on Blackcat you're nearly famous, share it around ...
            Let me share a little insight into Dave's demur:
            (Click the below link)
            http://www.copytechnet.com/forums/ra...ighlight=poems
            It's just all in a days work for some....
            • Qball
              • Jun 2013
              • 127
              That was outstanding!
                • 23009
                Oh common Blackcat you're nearly famous, share it around ...
                Ok, Ok.
                So my customer does a lot of LTR-R booklets in this FS-532 finisher, and quite often leaves a few in the back of the finisher, behind the stacker tray and SD-510. I had my arm shoved in there almost to the elbow and was about 25mm short of reaching the paper. With one huge shove I got the elbow past, and reached the booklet! Hooray!!
                Usually I'm on this site by myself, but purely by accident the salesman was there with me. After about 10 minutes of pushing and pulling, and not really getting anywhere, I finally decided I was going to need some help.
                "Hey Rick ... I seem to have a problem."
                "What kind of a problem?
                "...um, I seem to be stuck."
                I'm on my knees, leaning on my left arm, and up to the shoulder in the finisher. Rick knows which end of the screwdriver to hold, but that's about as far as it goes for him.
                "You see that screwdriver on the floor? Can you remove the screws that hold that rail?"
                "What screws?"
                "Just remove any screws you can see."
                This is about when the numbness and tingling starts in earnest. I'm trying to find that "comfortable" position, but I don't think there is one. Each time Rick leans on the finisher I feel another zing from the pinched nerve. He's got about 20 screws on the floor now, but nothing has moved yet.
                Rick says "We should call the fire department."
                "What do you think the fire department will do? They'll get the Jaws-Of-Life and chew a big piece out of this finisher."
                "What else can we do?"
                "Maybe there's another tech in the area. Use my phone and call the dispatcher. Find out who's close."
                So he makes the call. The nearest tech is 40 miles/40 minutes away and is re-directed to my location. I don't feel the arm at all any more, and I don't think that's a good thing.
                "Let's try this again Rick. Can you see the rail on the left side? Are there any screws in it?"
                "How's the arm?"
                "It doesn't hurt anymore. Look for those screws."
                "There's only one left ... right here."
                Then the SD-510 drops about 2 inches, and the tingling returns to my arm and it slides right out. The first call is to the tech, to go on to his next call. The next call is to the manager. No I won't be taking a finisher home with me.
                I did learn something. If your arm doesn't quite fit, don't continue to shove until it's irretrievably stuck. And if you do, bring along a salesman to save your ass. =^..^=
                  • 37532
                  Ok, Ok.
                  "What screws?"
                  "How's the arm?"
                  I think you have posted this before because I remember reading most of it.
                    • 23009
                    It's the CRS. =^..^=
                    • Qball
                      • Jun 2013
                      • 127
                      Heck of a story, Blackcat. I think even I could avoid doing that more than once. I think.
                      • sturmtrooper
                        Copier Combobulator
                        • May 2016
                        • 587
                        I stuck a BCU for a 6002 in a 6001. The machine will boot and it will not otherwise complain as far as I know. The dipswitch settings are not the same though.
                        • Polo-022
                          • Sep 2007
                          • 486
                          • nekowaiidesu
                            • Dec 2015
                            • 65
                            I am still quite new to this line of work but I have learned something very important: don't get too comfortable around electricity. Twice within a single month I've zapped myself by being careless. Not fun.
                            • qbert69
                              • Mar 2013
                              • 1152
                              Ok, Ok.
                              "What screws?"
                              "How's the arm?"
                              Chinese smartman say yoo can keep you arm for five dolla ninty nine cent with this tool!:
                              12" Locking Clamp
                              ...or this one dual purpose for two dolla ninty nine cent!:
                              24" 2-in-1 Pickup Tool
                              LOL!
