Ricoh Pro C 900 s J038
  • bojans
    • 1313
    Hello,
    Could anyone help me with this constant jam 038.
    Machine was working and suddenly jam 038 occured.
    It jam in fuser all the time with any paper.
    • 37556
    Re: Ricoh Pro C 900 s J038
    D016 JAM CODE 038 Fusing exit sensor, late: Refer to bulletin # 37..
    D016 JAM CODE 038 Poor transport of paper to fuser. TSB G178/D016-037. Service Ref Guide Section 7.2
    • bojans
      • 1313
      Where to find tdis bulletin?
      "Refer to bulletin # 37.."
        • 37556
        Your Ricoh support web site.
        • bojans
          • 1313
          Cant find it.
          • bojans
            • 1313
            I had similar problem on other machine. There was problem only with thin paper.
            After I did Memory clear, machine started to throw sc codes , I think sc410.
            I put values from Factory set sheet back to machine and its working for last 5 months without jam.
            I did Memory clear-Engine to this machine and it shows SC410
            Then I have realised that I dont have Factory set sheet or smc report.😟
            Any help with this problem or to put other way:what do you do when execute Memory clear and dont have Factory sheet?
            • TonerMunkeh
              Professional Moron
              • 3865
              If you have an old SMC logging and SP mode data you could get it from that. What was the purpose of the memory clear?
              Hit it.
              • bojans
                • 1313
                Unfortunatelly I dont have it.
                I thought that I had it but it was from other machine. Realised later that it has dofferent serial number.
                Like I said I did it on one machine with same problem and it started to work. So that was the reason for memory clear.
