RICOH MC305SPF SC361-00 service code
  • Wbankard
    • Apr 2016
    • 18
    RICOH MC305SPF Black toner sensor exceeds specified value. Can that be caused by the end user twisting the cartridge? Best way of correcting this issue ? a sky copy total black? Several dark prints?
  • copier tech
    • 8145
    Re: RICOH MC305SPF SC361-00 service code
    SC361-01 refers to the BK pcdu.
    I'd check the pm life of the black drum unit replace that first. There is a known issue with the toner hoppers on this model. Its also important to keep the firmware upto date.
    • Wbankard
      • Apr 2016
      • 18
      How do I get into service mode and check the PM statis?
      • copier tech
        • 8145
        Ok so you're not a tech.
        I would suggest you book an engineer to call out, might just need the firmware updating.
        • Wbankard
          • Apr 2016
          • 18
          Over 40 yrs a tech, read my other posts.... I do not know much about this Ricoh... Certified HP tech [ printers and computers ], IBM, Levono, Sharp (old stuff), Mita Copiers, Early Ricoh, Compaq, Okidata, Royal Typewriters, Remington typewriters, IBM typewriters, Rotary Calculators, ect, ect, ect. Even have a toner vac.
          I still need to know how to get into the service mode. The I cannot find it in the service book.
          • copier tech
            • 8145
            lol that told me!
            To enter service mode press Yellow (reset) 1,0,7 hold C
            I'd start by updating all the firmware, I've added this below, download the files as a zip (you have the service manual so can read up on it) but simply unzip all the files into a folder called "romdata" on a blank SD card, shut down the 305 & plug it into SD card slot 2 (The lower one) then power on your 305. After a few mins the screen will show the firmware screen simply highlight them all & press #
            Hope this helps.
            MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 20GB now
            • Wbankard
              • Apr 2016
              • 18
              Thank you.
