how to create and delete a password for copier function MP 2501L and MP 3351
  • tan74112000
    • Jun 2025
    how to create and delete a password for copier function MP 2501L and MP 3351 ?
  • PillePalle
    • 42
    Re: how to create and delete a password for copier function MP 2501L and MP 3351
    hi
    First of all you need to set the Functions that will need a Code. You can make that on the webinterface (admin) under "Configuration" --> "User Authetification management".
    Once you set what functions will need a Code you set the Code in The Addressbookentry of the user. Also there you have to set the Code and then specify the functions he will need this code.
    If you only want to delete the code you can make that also in the Addressbook. But don`t forget to take away not only the code but also the functions that would use a code.
    I hope it helps.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Creating new user code: Registering a User Code
      Deleting user code: Deleting a User Code
      Enabling user codes (scroll down to User Authentication Management): Administrator Tools
