MPC 3002 Bad Print Quality
  • stefan1129
    Guest replied
    Re: MPC 3002 Bad Print Quality
    Using the procedure write by TonerMunkeh print is ok. If the problem reappears, it is possible to reset controller or you need to change controller?
    Thanks,
  • stefan1129
    Guest replied
    good morning,
    i have the same problem..there is a way to reset the controller?
    Thanks,
  • BLADE
    replied
    Originally posted by Roger67
    Hi Folks,
    after reseting the SP 1101-4 and a new ACC adj. the Machine runs well !
    Thanks for your Help
    Greetings
    Roger
    good one, where do we get the test chart
  • Roger67
    replied
    Hi Folks,
    Greetings
    Roger
  • TonerMunkeh
    replied
    Okay. It's the ACC that's affecting the copy quality. Run 5-801-008 again and don't ACC the machine.
  • BLADE
    replied
    reseat controller
  • Roger67
    replied
    After adj. the Machine again with your Infos,the Prints aren t looking good.
    See Att.
    PCL 19.7..pdf
  • TonerMunkeh
    replied
    Right. Change SP4-010-001 to -2.0mm. Perform a printer application memory clear SP5-801-008. Reboot. Run SP2-111 modes C then A, then ACC it. That should sort it.
    Also see: http://www.copytechnet.com/forums/ri...ght=4502+gamma
  • Roger67
    replied
    Hmmm,there was something special on my ACC Test Charts........please see the Att.
    ACC.pdf
    Cheers
    Roger
  • TonerMunkeh
    replied
    Oh hang on, I think I know what's going on here. Print out a printer ACC test pattern. Are the first 8 or 9 sections really pale then the the last 5 or 6 solid as anything?
  • Roger67
    replied
    Using the PS 3 Option,even the Print Quality is much more worst than the Examples with the
    PCL Driver.
    See att.
    PS Driver.pdf
    Printing the same File on a MPC 4503 using the PCL Driver,the Quality is good.
    We almost changed every Board,the Novram etc. in the Defectiv MPC 3002.......
    Now we dont now,what to do !
    Cheers
    Roger
  • TonerMunkeh
    replied
    Bearing in mind you're using an office MFP using the PCL driver and not Postscript, the shift in resolution will cause the machine to use more process black in the image creating your colour differential. You're never going to get a perfect colour match on this machine.
    Anyhoo run line position adjustment, run process control and then ACC it. Make sure all your PM parts are in life.
    On a lighter note, that is some epic sideboob.
  • Roger67
    started a topic MPC 3002 Bad Print Quality
    Hello,
    i have a problem with a MPC 3002 during print outputs with higher resolution.
    With 1200 x 1200 dpi the resolution in the black parts of the Pic looks good.
    With 2400 x 600 dpi the resolution in the black parts of the Pic looks bad.
    See att.
    Im using a PCL 6 Driver and the FW: PCL 1.15 / System 2.16 / Engine 1.10:04 / PDF 1.04
    Thanks for help
    Roger
    MPC 3002.pdf
