mp9002 sc 142
  • en.
    • Jul 2014
    • 124
    mp9002 sc 142
    hi all
    i have problem with ricoh mp9002 its give me code sc142 directly after i turned the power switch
    i checked and do all this action
    1: cleaned all optic section and mirror + lens +lamp is working
    2- cleaned all white plate and ex poser class for scanner and feeder
    3- checked all connector and harness
    but still give me these code any one can help me
    best regards
  • keithxxiii
    Just a tech
    • Nov 2014
    • 469
    Re: mp9002 sc 142
    Try to check the boards and swap them if you have some spare.
    Could be the IPU
    Aye! Cut the crap
    • en.
      • Jul 2014
      • 124
      Re: mp9002 sc 142
      Originally posted by keithxxiii
      [ATTACH=CONFIG]33573[/ATTACH]
      Could be the IPU
      thanks my friends for your responding
      this is a problem i don't have spare part for it >>is the mp9001 is the same part for scanner ?
        • 37491
        Re: mp9002 sc 142
        When you first turn the MP 9002 on, does the scanner move to below the white reference and the lamp turn on?
        • en.
          • Jul 2014
          • 124
          Re: mp9002 sc 142
          Yes my frinde scanner motor is working and lamp is on
          • whitecat
            • Nov 2012
            • 43
            Re: mp9002 sc 142
            Disconnect scanner from machine , and give it a try . SC`s on this machine are misleading . Who made the service manual has high/drunk, idk.
