MPC3500 SC 202
  • digicor
    • 1159
    MPC3500 SC 202
    Ive changed the laser unit, could someone tell me where the polygon driver board is located ?, the code relates to the driver motor, but is this really the issue? could this be a false code for another problem?
    any help thanks
  • LNorris
    • Sep 2008
    • 645
    Re: MPC3500 SC 202
    your polygon motor/board is item 4 in this pic.
    laser.jpg also, try disconnecting hard drive and boot and see what happens, i had a c4500 do this to me
    • keithxxiii
      Just a tech
      • Nov 2014
      • 471
      Re: MPC3500 SC 202
      Usually the SC202 has no display, blown polygon motor/board and the BCU. Always check the BCU after replacing the polygon mirror motor or laser unit.
      Aye! Cut the crap
      • imaginemoko
        unTrusted Tech
        • Jan 2008
        • 289
        Re: MPC3500 SC 202
        after replacing LD try replacing your BCU Sir, just don't forget the old nvram. and machine serial later on you need to encode it with your new BCU usually gives you error 954 after turning on. good luck.
        fix the customer first then fix the machine... its simple and makes life more easy.
        • Oze
          Ricoh Fanboy
          • 1663
          Re: MPC3500 SC 202
          Replace the Polygon Mirror motor AND the BCU at the same time or you'll keep chasing your tail....like...you...are...now
          • HDSB
            Field Tech
            • Feb 2013
            • 64
            Re: MPC3500 SC 202
            This!
            • gear13z
              • Sep 2011
              • 68
              Re: MPC3500 SC 202
              most of the time BCU is been defective, when your polygon is been defective it will be no display, only the green light is on. usually result of fluctuating current.
              .....with all it shams, drudgery, and broken dreams, it is still a beautiful world.....
              • digicor
                • 1159
                Re: MPC3500 SC 202
                Thanks Guys
