1027-R in 3350
  • tinfox
    • 317
    1027-R in 3350
    I went to replace the PCU in a 3350 which already had a 1027 PCU but the new one wouldn't slide in all the way. Is there a pin or something that needs to be removed?
  • copyaction
    • Oct 2007
    • 991
    Re: 1027-R in 3350
    I had one once that the slider for the toner door cover was hitting the frame on the way in
    • jonhiker
      • 661
      Re: 1027-R in 3350
      Yes, there is a plastic pin that needs to be clipped off. It's on the lower part of the pcu. i would like to describe the placement better, but it's been a while since I worked on one of those machines.
      • sandmanmac
        • 3983
        Re: 1027-R in 3350
        No modification required for 1027 PCU for use in any model up to at least the MP2852/3352 series.
        (There are mods/ pins to be snipped if you want to go the other way and use the MP2550, etc PCU in the older 1027/2027 series)
        No harm in snipping the pin(s) off the back end of the unit if you want, but you must be missing something, or there's something wrong with the replacement unit
          • 37553
          Re: 1027-R in 3350
          Make sure you actually have a Type 1027 PCU and not a Type 320. The only difference is the position of the pin on the back of the front plate. If you are buying rebuilt PCU's, since you have R in the title, someone might have rebuilt a Type 320 thinking it was a Type 1027.
          • tinfox
            • 317
            Re: 1027-R in 3350
            My bad! Its actually a 3352! Does that make a difference? I pulled a pcu from a 2550 and that wouldn't go in all the way either...
            • TonerMunkeh
              Professional Moron
              • 3865
              Re: 1027-R in 3350
              Yeah, they are different. Take the PCU shutter gear assembly off the front. Under that is the pin / lug assembly. Swap it from the old to the new and it will fit.
              Hit it.
              • tinfox
                • 317
                Re: 1027-R in 3350
                Thanks, I'll let you know how it goes.
                • tinfox
                  • 317
                  Re: 1027-R in 3350
                  So I had to break off the tiny pin in the pic. Ran 2801. That is all. (hopefully )
