Ricoh MPC3002 Scan to Windows 10
  • DBT
    • Jul 2011
    • 24
    [Misc] Ricoh MPC3002 Scan to Windows 10
    Hello all-
    I was hoping someone might know why i having a problem setting up smb scan to multiple windows 10 workstations. I can scan to windows 7 with no problem. I can see the computers when i browse, but when i try to login it gives me an authentication error. I was wondering if it has anything to do with the username having a space? I have updated all the firmware as well (same results).
  • LNorris
    • Sep 2008
    • 645
    Re: Ricoh MPC3002 Scan to Windows 10
    have you loaded the custom firmware for scanning to windows 8? also, win 8 and 10 require username and password
    • mbolduc
      • Jun 2015
      • 53
      Telnet in to the NIC on the machine and set smb client port to 445.
      Make sure sharing is on under advanced sharing settings on the computer.
      A work around is to select 'store on hdd' on scan screen on MFP and create a link through the WIM to doc server and customer can download scans from machine and can even password protect the scans. Can set docs to auto delete after a few days or customer can delete them as they take them off hdd. No authentication or forced network sharing needed. OLD school work around...
        • 37558
        I would say yes. I usually create a scan folder on the root directory of the HDD and a user named scanner with a password of scanning and give the user full rights to the scan folder.
        • steven@mostech.co.za
          Agree with LNorris.
          Update Network Support FW and System Copy FW and you will be a for away. If this has been done also check the clients Anti-Virus, you may have to add the SMB port to the exclusion list which originates from the printers IP.
          Regards,
          Steven
