Ricoh MP C3000 can not find black toner after Line Adjustment
Re: Ricoh MP C3000 can not find black toner after Line Adjustment
What else have you done to the machine? What was the fault you were called out for? -
Had this happen on a newer machine with cyan. Machine's memory got "scrambled" during an electrical storm. Toner bottle motor would not turn during copy/print run, but would operate in SP output check. It would also mark the RFID chip on every bottle as empty after 20 copies. SMC's Non-Default showed settings out of whack. Performed engine memory clear and it was fixed.Do what you can, with what you have, where you are. ~Theodore RooseveltComment
Had this happen on a newer machine with cyan. Machine's memory got "scrambled" during an electrical storm. Toner bottle motor would not turn during copy/print run, but would operate in SP output check. It would also mark the RFID chip on every bottle as empty after 20 copies. SMC's Non-Default showed settings out of whack. Performed engine memory clear and it was fixed.Comment
the pumps has been checked already,
it started with the Error code SC565 it is fuser problem we change the
and clear the error code, it work for about week.
then it started printing very bad. the colors were in line so I run this steps
- ACC Recall SP5-610-4
- ACC Recall SP1-101-1 in Printer SP
- Process Control SP3-011-1
- Process Control Result SP3-012 -> 11111111 (Eg: 11(Y)11(C)11(M)11(K)
Note: * Anything other than ‘11’ indicates a problem
- Line Adjustment C SP2-111-3
- Line Adjustment A SP2-111-1 Execute twice
- Printer Test Page SP1-103-2 in Printer SP
now it print perfect very few like 5x then it can not detect one of the toners I really don't know why
I have try different toners sameComment
Live for yourself and you will live in vain. Live for others, and you will live againComment
we have 2x Ricoh MP C3000 with the same problem and I believe is a unstable power supply errorComment
