Ricoh MPC 3002 SC 672
  • StephenB
    • Aug 2015
    • 244
    Picked up a MPC 3002 off lease. When powered on screen says " ,hard disc replaced, needs formatted" execute format and then SC 672-000.
    If I disconnect the hard drive, system comes to ready and functions ( no scan function ) I figure this means the controller is ok.
    I notice the hard drive with the MPC 3002 is 100GB, where specs call for 190GB. ( I don't have a 190 GB or larger to test with ) Is this "smaller hard drive
    causing the SC 672 ? and do I have to use a 190 GB to repair , or can I go larger ?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh MPC 3002 SC 672
    More than likely the previous owner removed the HDD to be destroyed, and replaced it with whatever could be found.
    Any similar sized HDD should work.
    See for more info on SC672: SC672.pdf
    • StephenB
      • Aug 2015
      • 244
      Thanks , that is what I thought as well. Just to confirm, can I install a larger HDD like a 200GB or does it need to be exact 190GB match ?
      • logrady2331
        • Feb 2011
        • 301
        No, as long as the replacement (target) is the same OR larger. I've put 500 gig HDD's in and they work just fine. Just replace it and format it in mode 5.
        • StephenB
          • Aug 2015
          • 244
          Thank you ! just ordered one...
          • StephenB
            • Aug 2015
            • 244
            Thank you everyone, just installed a 250GB formatted and set up perfectly !
            • TonerMunkeh
              Professional Moron
              • 3865
              Just make sure you copy the stamp data and initialise the address book with 5846-047.
              Hit it.
              • logrady2331
                • Feb 2011
                • 301
                Just in case there are a few who don't know, an off the shelf HDD from Frey's Electronics, Best Buy, etc. work just fine. 50.00 or 60.00 bucks......
                • StephenB
                  • Aug 2015
                  • 244
                  Mr. Munkeh...I noticed the stamp data is not all there, can u fill me in on "copying the stamp data" . What is the procedure ? Thank you...
                  • ruben
                    The New Guy
                    • Oct 2012
                    • 1203
                    Run SP5-853 Stamp data download, then restart machine.
                    • simonsays
                      • Aug 2013
                      • 95
                      Originally posted by stephenb
                      thanks , that is what i thought as well. Just to confirm, can i install a larger hdd like a 200gb or does it need to be exact 190gb match ?
                      you can install a larger on in if thats what you have but dont go smaller or you will have issues i have installed many larger ones with no problems
