Ricoh 2851 Scanning to Windows 10
  • service.buck@gmail.com
    • 8
    I have a Ricoh 2851 that I need to set up scanning at an office with windows 10. Everything else works fine
    with win 10 but I cannot scan. Does anyone have a solution?
  • LNorris
    • Sep 2008
    • 645
    Re: Ricoh 2851 Scanning to Windows 10
    i didnt see any custom firmware for scan. are you using username and password?
    • mikedci
      • Jul 2010
      • 227
      Firmware up to date? System needs to be 1.03 or higher and network needs to be 7.38 or higher...
      • logrady2331
        • Feb 2011
        • 301
        If it will scan to 8 it will scan to ten. More than likely just a firmware upgrade for win8, srvr 2012 and 2012 r2.
        • richardjj
          Technician - I.T Support
          • Feb 2010
          • 18
          See my post "MP4001 & Windows Server 2012 r2" might help ?
          • apump
            • Mar 2009
            • 160
            under special firmware you need to choose NCS and update that. make sure they have win 10 professional and not the free upgrade of home edition.
            • gear13z
              • Sep 2011
              • 68
              try FTP scan instead of SMB, use the filezilla server.
              .....with all it shams, drudgery, and broken dreams, it is still a beautiful world.....
                • 37606
                Check with the customer's IT before you try using FTP.
