RICOH MPC2051 (Printing problems)
  • omorales
    • Mar 2015
    • 86
    Hello amigod I wonder if someone had this problem.
    SMC when printing in all ok, but when I print the PCL settings, from 4 Printing the print is mounted enterior.
    Attached images of the error.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: RICOH MPC2051 (Printing problems)
    Looks like a fusing problem.
    Make sure the trays are set to the correct paper weight, and the printer driver matches.
    Check the fuser sleeve, lamps, and pressure roller for damage.
    • TonerMunkeh
      Professional Moron
      • 3865
      Either the fuser is toast or the pressure lever actuators on the door are broken,
      Hit it.
      • mbolduc
        • Jun 2015
        • 53
        Looks like from your print out that 1105 values have been adjusted to lower temps. I would increase them to default or 10 degrees higher than default. Also figure out if the bad pages come out first or last in your set. If they are first, then think about raising your firmware levels to most current available, and turn off energy saver for a couple days to see if that helps.
        Good Luck
          • 37533
          If this only occurs when printing and not when copying, check the paper type setting in the driver and in the document. Check User Tools - Printer Features - System - Tray Setting Priority. Bypass should be set to Driver/Command. All trays should be set to Machine Setting.
          • omorales
            • Mar 2015
            • 86
            Hi, thanks for the answers.
            Today making further review, I realized that this problem is only when there is enough coverage black.
            The impression of the SMC settings without any problems.
            I have asked the cleaning unit and BELT UNIT:ASS'Y
            • banginbishop
              grumpy old git
              • Oct 2007
              • 894
              There is a bulletin for adjusting sp1-112-002
              Take a look at Rd104037
              Incontinentia Buttocks
              • omorales
                • Mar 2015
                • 86
                Thank you banginbishop.
                The sp solved the problem
                Traductor
                Detectar idioma
                Thank you
                • banginbishop
                  grumpy old git
                  • Oct 2007
                  • 894
                  Your welcome😄
                  Traductor
                  Detectar idioma
                  Thank you
