Mpc4502 pcu same as?
  • mrfuser
    • 1622
    Does anyone know if the MPC 4502 drums are same as any other models ? I saw that she cheats that somebody else had made but it really doesn't make a lot of sense to me when it gets to the 4502 . Looks like some say the 4000 is the same but I'm just not sure , would appreciate some clarification.
    K
  • keithxxiii
    Just a tech
    • Nov 2014
    • 469
    Re: Mpc4502 pcu same as?
    Same as D0292256. PM me so i can send you the full list and the steps to modify them.
    Aye! Cut the crap
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      D029-2256 or B224-2042 will fit in all most models up to, and including, the 02's.
      For B&W, remove the metal pin from the connector, and cut to fit. Then swap the face plate from the original drum.
      For colour, do the same, but remove the metal pin from inside the machine, and swap the two right wires on the dev connector.
      My own cheat sheet (with pictures from original cheat sheet): Drum mod.pdf
        • 37532
        Originally posted by ruben
        D029-2256 or B224-2042 will fit in all models up to, and including, the 02's.
        My own cheat sheet (with pictures from original cheat sheet): [ATTACH]33812[/ATTACH]
        Will not fit the MP C2050 series models or MP C2051 series models.
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          Good point.
          • Bantams
            • Jun 2012
            • 603
            MPC2500 BLK ones fit with no problems other than chopping the pins off etc. and are cheaper Just need to swap the front covers over
            Also for the 02s there's no wires to change
            • keithxxiii
              Just a tech
              • Nov 2014
              • 469
              Ruben's Cheat list is more accurate than mine
              but be careful when filing the edge of the connector. If you overdo it, some sc codes could come up (PCU Disconnected)
              Aye! Cut the crap
