Mpc3300 exit motor jam
  • mrfuser
    • 1627
    Anyone seen this jam? Exit motor jam, N service mode shows up under jams at 166 , exit motor jams. Of course works great when I'm at client.
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: Mpc3300 exit motor jam
    Does the machine have a bridge unit and/or finisher installed on it ?
    If so, you may like to disable/remove the redundant exit tray-full-sensor "plug" off the tray-full sensor. The now redundant sensor becomes dusty and can flag intermittent errors...
    HTH
    • mrfuser
      • 1627
      Is that plug located on the finisher or bridge or is it located on the machine itself at the exit going into the bridge?
      • NeoMatrix
        Senior Tech.
        • 3513
        Re. Sensor location:
        On the machine itself. The sensor is on the end of the exit-full lever that hangs down.
        This is the lever that is folds out the away when you install the new bridge unit option.
          • 37653
          Check the bushings in the exit unit. Heat from the fusing unit can cause them to seize.
          • Zeldaman
            • Mar 2011
            • 946
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              +1 FOR THE EXIT ASSY.
              You can now purchase the complete assy as a replaceable unit (Only took Ricoh 6 years)
                • 37653
                A couple of drops of Kroil or Marvel Mystery Oil will penetrate in and free the bushing up. Still have to replace the bushing and shaft. Frequently the gear will round out and have to be replaced. A drop of silicon oil on each of the bushings when the fusing unit is PMed will prevent future problems.
                • mrfuser
                  • 1627
                  Part number for new exit unit?
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    D0294405
