mp201
  • apump
    • Mar 2009
    • 160
    [Error Code] mp201
    has anyone ever replaced the front door switch on a mp201? I have one that's not working giving SC320 code and I tried looking at how it comes out, looks like it isn't fun. Couldn't find it in the service manual.
    • 37508
    Re: mp201
    SC 320 is a polygon mirror motor error. Replace the polygon mirror motor.
    • copyaction
      • Oct 2007
      • 991
      Re: mp201
      It also gives this code when no toner cartridge is installed
      • nmfaxman
        • 1702
        Re: mp201
        Make sure toner hopper and toner are installed.
        If switch is bad, jump the connectors to make it think they are there.
        Never understood why that switch was there.
        • apump
          • Mar 2009
          • 160
          Re: mp201
          it has toner bottle and toner supply unit it there. im sure its the switch cuz in service mode it will not change state like the right door switch. and I checked another 201 for front door switch to see if it changed and it did.
            • 37508
            Re: mp201
            Check the point to point. The switch for the toner bottle insertion, laser safety switch, might be in series with the front door switch.
            • apump
              • Mar 2009
              • 160
              Re: mp201
              ok. your thinking still laser?
              • sandmanmac
                • 3981
                Re: mp201
                I'm not sure what your reasoning is for it not being the laser motor
                There is no documentation that I've seen to suggest anything other than that, or possibly the BICU
                • katash
                  • May 2010
                  • 221
                  Re: mp201
                  Replace the laser unit
                  • apump
                    • Mar 2009
                    • 160
                    Re: mp201
                    the reason im saying door switch is because its not changing state when checked, so if you don't have 24v from it then laser will not fire up anyway. but I went ahead and ordered a laser this morning so we shall see. thanks
                    • ruben
                      The New Guy
                      • Oct 2012
                      • 1203
                      Re: mp201
                      I have found the poly's on these models are reliable, but can sometimes cause noise / code issues.
                      Removing the laser can be a pain in the ass, if you don't already know how to do it. (Skip this if you already do, but it may help someone else in the future):
                      You will need to remove the internal tray, toner hopper, PSU and metal plate underneath the internal tray (with power disconnected, of couse, and watch out for the capacitors); you will need a small screwdriver for this job, unpeal the two seals underneath where the hopper sits to get to the two laser screws, remove the single exposed screw, and disconnect the two cables. The LSU should pull towards where the PSU was sitting. Removing the poly is simple after that.
                      The first time I did this, I didn't read the manual; to know about the two hopper screws, and ended up removing the entire scanner section. Didn't RTFM when I needed to RTFM.
                      • apump
                        • Mar 2009
                        • 160
                        Re: mp201
                        another tech kindly worked on this copier for me in the shop, it ended up being the BICU. he put a laser unit in it and it didn't fix it so after bicu everything is working. could be possible the laser took out the bicu.
                        • Simza
                          Simza
                          • May 2020
                          • 27
                          Re: mp201, Error 320
                          Hi Friends,
                          i have SC320 in Aficio 201. I have replace the polygone motor und the power circut abouve the polygonemotor with outher used parts(which i have tested before install), but the code is still there.
                          Can everybody advise me how to recet the code in outher way.
                          Thanks and have good time
                          Stay safe
                          • sandmanmac
                            • 3981
                            Originally posted by Simza
                            Hi Friends,
                            Stay safe
                            A good next step would be to read the post directly above yours
                              • 37508
                              Hi Friends,
                              Stay safe
                              1. We are not your friends. We don't know you from shit.
                              2. This thread was nearly 2 years old, dead and buried. Start a new one if you want any help, grave digger.
