has anyone ever replaced the front door switch on a mp201? I have one that's not working giving SC320 code and I tried looking at how it comes out, looks like it isn't fun. Couldn't find it in the service manual.
mp201
Tags: None
Re: mp201
Make sure toner hopper and toner are installed.
If switch is bad, jump the connectors to make it think they are there.
Never understood why that switch was there.Why do they call it common sense?
If it were common, wouldn't everyone have it?Comment
Re: mp201
Check the point to point. The switch for the toner bottle insertion, laser safety switch, might be in series with the front door switch.Comment
Re: mp201
I have found the poly's on these models are reliable, but can sometimes cause noise / code issues.
Removing the laser can be a pain in the ass, if you don't already know how to do it. (Skip this if you already do, but it may help someone else in the future):
You will need to remove the internal tray, toner hopper, PSU and metal plate underneath the internal tray (with power disconnected, of couse, and watch out for the capacitors); you will need a small screwdriver for this job, unpeal the two seals underneath where the hopper sits to get to the two laser screws, remove the single exposed screw, and disconnect the two cables. The LSU should pull towards where the PSU was sitting. Removing the poly is simple after that.
The first time I did this, I didn't read the manual; to know about the two hopper screws, and ended up removing the entire scanner section. Didn't RTFM when I needed to RTFM.Comment
Re: mp201, Error 320
Hi Friends,
i have SC320 in Aficio 201. I have replace the polygone motor und the power circut abouve the polygonemotor with outher used parts(which i have tested before install), but the code is still there.
Can everybody advise me how to recet the code in outher way.
Thanks and have good time
Stay safeComment
Hi Friends,
Stay safeComment
Hi Friends,
Stay safe- We are not your friends. We don't know you from shit.
- This thread was nearly 2 years old, dead and buried. Start a new one if you want any help, grave digger.
