Ricoh MPC2500 toner
  • Fuzzylogic
    • Aug 2016
    • 33
    Ricoh MPC2500 toner
    Hello There
    I have a Ricoh MPC2500 that keeps saying that the black "toner has been depleted" a week after a new toner bottle has been installed. I have replaced the toner pump, the black developer and the drum. The machine will come good after SC3045 is toggled from detect to non detect. It then runs for a week and the error "toner has been depleted" comes back. I would like to upgrade the firmware if somebody has it .............or any other suggestions.
    Regards
  • bob marley
    • Jan 2012
    • 1339
    Re: Ricoh MPC2500 toner
    Originally posted by Fuzzylogic
    Hello There
    http://www.copytechnet.com/forums/ri...r-problem.html
    Live for yourself and you will live in vain. Live for others, and you will live again
    • jonhiker
      • 661
      lots of good suggestions in this link. i had te same issue and vaccuuming out the the hose fixed it.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Hello There
        Regards
        Turning off End Detect is a temporary measure that most techs use on a local machine...e.g. a machine in town has a toner supply issue so you turn off end detect while you race back to the workshop to grab a pump.
        It should NEVER be used as a permanent fix because it will strip all the toner from the dev and throw a TD error.
        In short..it never fixes it just hides the issue for the end user.
        And failed pumps in these models are commonplace
          • 37542
          Hello There
          Regards
          It comes back because the toner bottle is now empty. Change AP 3045 back to Detect and install a new bottle. If "Toner has been depleted" then comes back, replace the RFID board on the C2500.
          It allows the machine to be able to operate. If the toner pump is bad, yes the image density will start to decrease and a TD sensor error will result. Problem identified. If the pump is not bad, the toner sensor on the back of the toner nozzle will detect that the bottle is empty and give a toner near end warning. A set number of copies later, a toner end condition will be displayed.
          • mikadonovan
            • May 2008
            • 2931
            I have had to do this also after just installing a new pump, and it resolved the problem.
            NEVER ASSUME ANYTHING
            • tufbnme
              • 493
              2nd the pump replacement
              • talahah
                • Sep 2017
                • 1
                Off detect chip
                  Originally posted by talahah
                  Off detect chip
                  what?
                    • 37542
                    what?
                    Turn
                    Off detect chip
                    SP 3045
                      Turn
                      SP 3045
                      thanks Brother... couldn't finger out what was trying to be conveyed!
