Ricoh Aficio 1045 SC 401 Error Code
  • tcypy1961
    • 773
    I have been working on this Ricoh Aficio 1045 and I continuously receive an SC-401 error code on it. I have been called out for the same error code three times now, so I am curious if the problem occurs more often due to the unit, or the copier itself? I have replaced the transfer belt assembly with a different transfer belt, and I have also cleaned the transfer PCB connections and the position clutch. Is there anything I have missed that could still be causing this error code? Thank you for any help given.
  • bob marley
    • Jan 2012
    • 1339
    Re: Ricoh Aficio 1045 SC 401 Error Code
    Originally posted by tcypy1961
    . Is there anything I have missed that could still be causing this error code? .
    High voltage supply board could be defective or poor cable connection
    Live for yourself and you will live in vain. Live for others, and you will live again
      • 37382
      Machine side contact assembly could have a hairline crack.
      • Zeldaman
        • Mar 2011
        • 946
