Ricoh pro c7110x
  • Viet nguyen
    • Nov 2015
    • 18
    [Misc] Ricoh pro c7110x
    I bought a used Ricoh Pro C7110
    it was tested and ran properly but only the color White and Clear did not work.
    Please help me
    Tks
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh pro c7110x
    Ok, I see you waited a month and reposted this. Here's your situation: You purchased a complicated Pro model Ricoh, and it is having issues. At the VERY LEAST you require a service manual and the training to understand what it says. Save yourself time and headaches by calling a service tech.
    NEVER ASSUME ANYTHING
    • sharpmind
      • Sep 2009
      • 478
      Please help me
      Tks
      There is a replacement kit for clear and white. Make sure that you do not interchange them otherwise you'll face color quality problem.
      • Viet nguyen
        • Nov 2015
        • 18
        the name of part : replace kit? where i can buy it
          • 37491
          The first thing that you need to do is determine whether you have a 4 station Pro C7110 or a 5 station Pro C7110x. You also need to check SP 3106-001 and SP 3107-001.
          • Viet nguyen
            • Nov 2015
            • 18
            I have 5 station
            I will check these sp mode today
            • Viet nguyen
              • Nov 2015
              • 18
              I have 5 station
              This problem sloved
