Mpc305SPF defectiv Gear from Fuser
  • nkot^1
    • Sep 2013
    • 17
  • Zeldaman
    • Mar 2011
    • 946
    Re: Mpc305SPF defectiv Gear from Fuser
    Hi there!
    If you look in the newest version of the 3D-partskatalog, there are 2 new numbers for the gears of the fuser. The newer machines are equipped with the mod. gears.
    Since this change, we have no more fuser-problems.
    Greetings...
    • banginbishop
      grumpy old git
      • Oct 2007
      • 894
      Originally posted by Zeldaman
      Hi there!
      Greetings...
      Incontinentia Buttocks
      • nkot^1
        • Sep 2013
        • 17
          • 8192
          Same here, just fit a new fuser, it's not worth just replacing individual parts.
          These little 305's are only good for light use, ideally suited for the home user, in a busy office they fall over all the time.
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            We used to replace the fuser sleeve on these, until we discovered a complete fuser unit was 3 times cheaper.
            Gears are easy to replace if you want to save some money.
