Ricoh Aficio 1035 Door Open Indicator
  • tcypy1961
    • 773
    What would cause this copier to periodically beep, indicating that a door is open but a door is not open? Thank you for any help possibly.
  • bob marley
    • Jan 2012
    • 1339
    Re: Ricoh Aficio 1035 Door Open Indicator
    Originally posted by tcypy1961
    What would cause this copier to periodically beep, indicating that a door is open but a door is not open? .
    defective switch or fuse (BCU)
    Live for yourself and you will live in vain. Live for others, and you will live again
      • 36857
      If the machine is in a high dust location, replace all the little push button door switches. I have even had a flaky harness in the interchange unit going to the door switch for door C.
      • nmfaxman
        • 1702
        I agree. Seen it many times.
