Aficio 2060 - replace cleaning web
  • Toner Boy
    • Aug 2007
    • 365
    OK, this has got to be a dumb question BUT someone has replaced the web on a fuser rebuild and the message is still there...
    Can't find a reset for WEB in the PM parts list or in service mode. I must not be looking in the right place. (Sharp tech mostly) Web sensor causes the web to spin when I cheat it. Sensor arm appears to be in the proper location on the supply side of web roll.
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    In SP mode:
    • Toner Boy
      • Aug 2007
      • 365
      most excellent!
      Thanks for the quick response Baphomet, much appreciated.
      • SGT_Snacks-64
        • Oct 2007
        • 157
        If it's not this I've had a previous engineer break the actuator for the Web end sensor, causing the SC 550 code. Don't know if it's easy to break them, never have done myself but who knows.
        Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
        Asus P5E-VM HDMI
        4GB (2x 2GB) Corsair XMS Xpert II RAM
        ATi Radeon 4870 512MB GFX Card
        2x 74GB WD Raptor Sata HDD (RAID 0)
        500GB Seagate Barracuda Sata II HDD
        500GB Hitachi Sata II HDD
        600W500att OCZ PSU
        -TOTAL HDD SPACE 1148GB-
        • hodgiepodgie
          • Jul 2008
          • 284
          Yep breaks easy . Also can be installed wrong. But try the code i did that myself . Ricoh seattle liked to send me on calls w/o trng me.i know whining.
          • rthonpm
            • Aug 2007
            • 2854
            I've also seen a couple of these that don't like getting that re-set at 0. They flake out unless you put the PM counter to 1...
