Ricoh MPC 3002 Double Side jamming
  • PJF
    • Jul 2014
    • 32
    I have a Ricoh MPC 3002 which gives up random double sided jams. Frequency of the jam is random can be at the start of a double sided run or 100-200 pages into a run. The jam is always the same (J001) Paper at Rego, paper in fuser, paper in Duplex. When printing out a SMC it doesn't give a jam location it just records the jams as a Power on Jam.
    Things I've tried
    Laser
    Door Switches
    Fuser
    Interchange unit
    PSU
    High Voltage Board
    Is there a Mod or firmware fix for double sided jamming on this model?
    Engine firmware is currently at v1.02.04 D1425116D
  • davel
    • Oct 2011
    • 1107
    Re: Ricoh MPC 3002 Double Side jamming
    Check main switch and monitor AC supply.
    • solorajder
      • Jul 2010
      • 106
      Bented duplex entrance plastic
      Sent from my GT-I9195I using Tapatalk
      • PJF
        • Jul 2014
        • 32
        Inspected the guide doesn't look bent, they have the metal bar inside to stop the warping problem the earlier mpc models had.
        Just tried a whole side door from another machine(which doesn't seem to have the jam problem), still got the same random power on jam issue.
        • Mark Bbb
          • Jun 2012
          • 1662
          Is a bridge unit installed?
            • 37533
            Since it show as a J001, you have a flaky door interlock switch somewhere. Since it only happen during duplex copying , it is probably the small push switch for the right jam access door.
            • anothertech
              • 1771
              You are running with the original firmware, the latest firmware says this: Margin improvement for some sensor detect errors caused by electrical noise.
              Probably worth the time to go ahead and get all of the firmware up to the latest. Even if it does not help, it couldn't hurt.
