MPC 3502 Question
  • fshead
    • 2360
    MPC 3502 Question
    hi
    i have not seen this box in person but read issues wth the danm fuser flaws.
    As i have not seen any MPC 3501 units with low meters would you go with a mpc3502?
    or is it just a headache.
    are the pcu units the same?
    thanks in advance
  • johnyb
    • Feb 2011
    • 167
    Re: MPC 3502 Question
    They are good machines and you can use the B2242042 drums
    Fusers wear earlier than stated depending on what paper / coverage!
    • TonerMunkeh
      Professional Moron
      • 3865
      With regard to the fuser, change the stripper plate with a fusing sleeve. They run a lot longer if you do.
      Hit it.
      • fshead
        • 2360
        thnx
        i did see some posts on here with the fuser taking out the BICU brd.
        That is I hope not an issue as
        "popping boards" is one issue that would keep me away from both making money and keeping
        accounts happy.
        i just dont get why Ricoh has to change "THE WHEEL" all the time when the previous box worked fine...
        • TonerMunkeh
          Professional Moron
          • 3865
          Indeed. Also, as a precaution, change the fuser exit motor if the entrance guide has toner smeared on it. That can cause you all sorts of issues.
          Hit it.
          • fshead
            • 2360
            ok
            are you talking machines with over 200k or more?
            i try to pick up machines with less than 100k total.
            if i have to rebuild fuser unit,it s not a deal breaker but adds
            to my margin and all.
            does the fuser exit motor stall from toner smear?
            thnx
            • TonerMunkeh
              Professional Moron
              • 3865
              Originally posted by fshead
              ok
              thnx
              This fault affects ALL the '02 MPC's up to a certain serial number. If you get smeared toner, replace the motor.
              Hit it.
              • logrady2331
                • Feb 2011
                • 301
                fshead: If you look at the fusing sleeve you will see it's not a traditional heat roller, it "floats" like the hp's. This machine will rum 300 gsm pretty easy, all due to the "floating" sleeve. We keep the scraper clean and, like others have said, change the fuser motor if the toner smears. You can get the SPC830dn fuser and swap the entire loom over to the new fuser. Comes with a transfer roller also.
                • anothertech
                  • 1761
                  I guess I've been lucky to not run into the motor problem yet, I have a fair number of those machines out. Does anyone have the part number handy for that motor?
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    Good machines, but... You need to be shure your customar is indicating thick paper if he uses it. If he doesn't, the fuser sleeve roller will wear (very) quickly. I've tried to rebuild the fusing unit, it didn't work, I still get the smear prints... Probably others will give you good advice about this replacement... Good luck.
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      AX060430.
                      Hit it.
                      • fshead
                        • 2360
                        i use to do a lot of the hp printers 4200/4300 series till their replacement models turned to s..t,bad laser,bad design.
                        they used a heat plate inside a fuser sleave and 200k was the yield.
                        i will say i do appreciate the design of the ricoh color pcus and developer units especially after
                        dealing with the crappy type 1027 design leak-A-matics...
