MP C4502 firmware update
  • thurmmy
    • Aug 2016
    • 102
    I am trying to do firmware update on a MP C4502. When the screen come up everything looks normal, old & new firmware versions, I touch the one I wan up dated, the update box appears, but when i touch the update it just beeps and doesn't do anything else, tried both touch screen and keys no dif. No errors Any ideas? Thanks
  • Gary Bowen
    Bowdog
    • Mar 2008
    • 250
    Re: MP C4502 firmware update
    How long are you waiting before attempting the update? 5 minutes is not unusual. The newer "03" series takes even longer before you can execute the firmware update even thought the screen will show the firmware versions. I am sure the "02" series takes a little longer than the C3000's/C2800's etc.
    • francisco
      • Nov 2009
      • 168
      try whith another SD card
        • 37556
        If JAVA is installed and you did not stop it before shutting to install updates, you have to wait until JAVA has initialized.
        I had an instance where everything looked normal but when I hit update, it immediately came back to update done. It was a bad SD card. The folder entries were there but the files didn't read.
