Ricoh MP5000/ Lanier LD150 codes SC360
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    This is one where I was following other techs. The machine wasn't adding toner, coding sc360 and other print quality issues. I put together a good PCU out of used parts and changed the toner motor. It would run about 30 and code SC360. I found that the rj45 connector for the dv box was broke on the flange and not making connection. I replaced it and the codes stopped, but it also quit adding toner. If I unplug the connector, it adds toner, then codes the SC360. My question is, Would the problem be in the BICU or the sensor on the dv box?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP5000/ Lanier LD150 codes SC360
    If you can slide that PCU into another machine, check the TD sensor voltage reading. If you get a reading, the TD sensor is okay and it's the BICU. If not, you could be really unlucky and it's the TD sensor that took the BICU out.
    Hit it.
