Ricoh MP4001 knocking noise
  • Leebs14
    • Feb 2014
    • 457
    [Misc] Ricoh MP4001 knocking noise
    It appears to be coming from the finisher tray but I cannot see what's causing it?
  • Leebs14
    • Feb 2014
    • 457
    Re: Ricoh MP4001 knocking noise
    Is it caused by worn foam exit rollers as they are worn out and it seems to be where the noise is coming from
    • qbert69
      • Mar 2013
      • 1152
      Re: Ricoh MP4001 knocking noise - NINJAFLEX!!!
      Ricoh needs to RE-ENGINEER their crappy shit!--the FOAM gathering/exit rollers are NOT durable!--pisses me off to no end! When are they going to use a rubber material that DOES NOT break down and rot!? I'd like to see somebody re-engineer and 3D print some rollers with NinjaFlex and use the cores from the old rollers! https://ninjatek.com/
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • tufbnme
        • 493
        [QUOTE=Leebs14;532464]Is it caused by worn foam exit rollers as they are worn out and it seems to be where the noise is coming from
        I second the output rollers.
        • Leebs14
          • Feb 2014
          • 457
          Can anyone help me with a part number for these foam rollers?
          • sturmtrooper
            Copier Combobulator
            • May 2016
            • 587
            The part number is in the parts catalog for the finisher.
            Assuming it's the 1000 sheet SR790 finisher the part number is B352 2407 Reverse Roller - 20z
            If it has the 2000 sheet booklet finisher SR3020 or the 3000 sheet finisher SR3030 the part number is B478 3503 Gathering Roller: Sponge
            • Leebs14
              • Feb 2014
              • 457
              Thank you Sturmtrooper
