Ricoh MP C3300 latest firmware
  • joncostajon
    • Sep 2016
    • 7
    Hello,
    I'm new to the forum. I'm playing around with a Ricoh MP C3300, I want to have the latest firmware available, so I can have fun and enable things like Google Cloud Printing.
    System/Copy version is 1.23, PartNumber D0255562T. Serial Number starts with V158701...
    I can post more info on request if needed.
    I'm just asking for a firmware, I don't want to start a flame war! (I've read other posts)
    • 37491
    Re: Ricoh MP C3300 latest firmware
    Google cloud printing is not a firmware issue. It is a JAVA APP and might not be available for the MP C3300. If the MFP does not have JAVA, you will have to purchase it. The Cloud APP might also have to be purchased or at least purchase the licensing.
    • joncostajon
      • Sep 2016
      • 7
      Thanks for the info!
      How do I find if my printer has Java?
        • 37491
        See if there is an "Extended Features" option in User Tools
        • joncostajon
          • Sep 2016
          • 7
          Nope! There isn't only Copier, Printer, Scanner features.
          Any idea on the fw upgrade to get it compatible with MacOS?
            • 37491
            To scan or to print. The latest firmware will correct an Unable to scan to OSX versions 10.7 and 10.8. Later versions of OSX may require additional software on the MAC as Apple has discontinued support for SMB. There are other threads that will have the software that you will need. You might want t consider using FTP scanning.
            Even with the latest firmware you will nit get the features of the newer models. Firmware updates do not add features, they merely correct problems with existing features and problems caused by OS changes. As an example, the MP C3300 will not support scan to email if the SMTP server requires TLS or SSL.
            • joncostajon
              • Sep 2016
              • 7
              Thanks for the clarification.
              How can I search for 'features' then?
