Factory Reset
  • renzoh08
    • Oct 2015
    • 15
    Factory Reset
    Hello Copier nerds,
    Currently my company has bought 2 used Ricoh Aficio MP301spf
    during the installation process i came across a problem.I need to get into the web application of the mfp but its asking for a username and password, the following password i have tried in the web application are
    username: admin
    password: blank
    username: admin
    password: password
    username:admin
    password: admin
    I have also came across with supervisor and password blank, which it does log me in with success. but cant do anything with it,Just gives me Program/change administrator. From there i try to change administrator 1 but no luck, I have also tried selected administrator 2 and adding my own password just to work around it, but cant even click on admin2.
    I have entered the service sim mode with reset,reset,1,0,7,c but dont see a option for factory reset
    The bottom line for the post is to find a option where i can completely wipe everything from the machine
    any feedback would be appreciated
    thanks
    • 37532
    Re: Factory Reset
    If you can login with supervisor, that is all that you need. Supervisor can do one thing and one thing only, change the password for admin.
    • Mark Bbb
      • Jun 2012
      • 1662
      Re: Factory Reset
      If you don't get a fix with supervisor, the only way is ->
      print out all sp data, replace NV ram and put SP data back in...
      • Elmo
        • Feb 2010
        • 541
        Re: Factory Reset
        Login as supervisor change admin password logout
        login as admin changed admin 2 password
        turn off admin 2
        I Used To Live To Fix Things Now i Fix Things To Live
        • DougD
          2020 Retired
          • Sep 2016
          • 76
          Re: Factory Reset
          The trick when using Supervisor to reset the admin password is to click OK twice.
          Once after resetting the password.
          The second time to save the change.
          Then logout and log back in as admin.
          Once you're logged in as admin, then you can create more Administrators.
          • sturmtrooper
            Copier Combobulator
            • May 2016
            • 587
            Re: Factory Reset
            If supervisor log in is also password protected contact the people you purchased it from. If they are ethical and competent they should be able to tell you.
              • 37532
              Re: Factory Reset
              If you read his entire first, you would have noticed that he was able to login as supervisor.
              • abc
                Re: Factory Reset
                did you try password "blank" not as a word
                like this
                username: admin
                password:
                • francisco
                  • Nov 2009
                  • 168
                  Re: Factory Reset
                  Originally posted by renzoh08
                  Hello Copier nerds,
                  username: admin
                  password: blank
                  username: admin
                  password: password
                  username:admin
                  password: admin
                  thanks
                  hi
                  enter special sp mode
                  5-846-46
                  then restart machine
                  • sturmtrooper
                    Copier Combobulator
                    • May 2016
                    • 587
                    Re: Factory Reset
                    They do say reading is fundamental.
                    • bob marley
                      • Jan 2012
                      • 1339
                      Re: Factory Reset
                      that is right
                      Live for yourself and you will live in vain. Live for others, and you will live again
                      • tufbnme
                        • 493
                        Re: Factory Reset
                        Originally posted by francisco
                        hi
                        5-846-46
                        Ditto this
                          • 37532
                          Re: Factory Reset
                          hi
                          5-846-46
                          Why? He has already said that he can get in as supervisor. 5846-46 is only needed when someone has also changed the supervisor password.
                          • renzoh08
                            • Oct 2015
                            • 15
                            Re: Factory Reset
                            hi
                            5-846-46
                            where exactly do i enter those numbers?
                            • tufbnme
                              • 493
                              Re: Factory Reset
                              Oh Geeeeeeez, give it up.
