Factory Reset
  • renzoh08
    • Oct 2015
    • 15
    #16
    Re: Factory Reset
    Originally posted by tufbnme
    Oh Geeeeeeez, give it up.
    Wow! and you consider yourself a service manager??
    • eddy out
      • Oct 2016
      • 359
      #17
      Re: Factory Reset
      Actually, special service mode does not get you to sp5846-46. You will need to enter the factory service mode, Reset 143 C, C(hold) then go to 5846-46 to execute, then reboot. at this point you should reset both admin and supervisor to no password(leave them blank).
        • 36796
        #18
        Re: Factory Reset
        Originally posted by renzoh08
        where exactly do i enter those numbers?
        If you can login with supervisor, that is all that you need. Supervisor can do one thing and one thing only, change the password for admin.
        If you read his entire first, you would have noticed that he was able to login as supervisor.
        Why? He has already said that he can get in as supervisor. 5846-46 is only needed when someone has also changed the supervisor password.
        And you consider yourself intelligent? If you had read my previous post and had the intelligence to understand them, you would have already corrected your problem. Or did you lie in your first post that you could login as supervisor?
        • Maher
          • Oct 2016
          • 15
          #19
          Re: Factory Reset
          I think you don`t have to replace NVRAM - only clear it with SP 5801 .
          But first Upload NVRAM to SD card SP 5824 then clear NVRAM then Download NVRAM SP5825.
          Let me know ... I am good with Ricoh
          • eddy out
            • Oct 2016
            • 359
            #20
            Re: Factory Reset
            I got dinged for the best response ever. I know how to fix this.
            • eddy out
              • Oct 2016
              • 359
              #21
              Re: Factory Reset
              Classified information. .
              • anothertech
                • 1756
                #22
                Re: Factory Reset
                Look in your garage, next to the Corvette.
                • eddy out
                  • Oct 2016
                  • 359
                  #23
                  Re: Factory Reset
                  • mrwho
                    Major Asshole!
                    • 4299
                    #24
                    Re: Factory Reset
                    I'd wager not very good, if you resort to 5801 to solve this kind of problem...
                    Edit: Just noticed I'm replying to a 2016 reply, but still...
                    Mascan42
                    Ibid
