The book sez to check the harness, the fuses and relay.
I pulled the psu and check the four fuses I could find. All seemed ok.
The harnesses were not damaged either.
The customer had another fuser unit, so I installed it and there was no
change in symptoms. It did give me an SC547-03 once.
I just realized that after I installed that other fuser unit I forgot to reset
the code with 5810.
Guess I'm going back tomorrow. Any other advice I should have?
DR
the code with 5810.
DR
