aficio 1515
  • Gab
    • Aug 2015
    • 671
    aficio 1515
    Message right cover open . I close the right cover but whan coping it slightly moves to right and message appears.
    Any idea how to fix it?
  • techmann
    • May 2016
    • 41
    Re: aficio 1515
    Those doors are kind of crappy. I used to put some electrical tape where the hook from the door latches to the frame. I would also beef up the interlock switch actuator, to make better contact with the interlock.
    • Mark Bbb
      • Jun 2012
      • 1662
      Re: aficio 1515
      Check if a hook is broken.
      • MitchD
        • Oct 2012
        • 164
        Re: aficio 1515
        Easy fix. There is an opening near the front frame side on the right of the machine that hold the door interlock. The metal actuator gets bent and doesn't fully activate the switch. I just use a small screwdriver and bend it back out slightly so the tab on the right door pushes it in further.
        Good Luck - Mitch
        "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
        • copier tech
          • 8172
          Re: aficio 1515
          The best fix is to BUY A NEW MACHINE!
          • bob marley
            • Jan 2012
            • 1339
            Re: aficio 1515
            yeah that is best solution
            Live for yourself and you will live in vain. Live for others, and you will live again
            • sturmtrooper
              Copier Combobulator
              • May 2016
              • 587
              Re: aficio 1515
              Customers are rarely so kind. You often have the choice of either supporting the machine or losing them as a customer, at least until you can no longer get parts for the machine.
              Too many people look at MFPs like they do their washing machine or stove "But it's only 5+ years old!" it's an electronic device, not an appliance.
