ft 4822
  • Gab
    • Aug 2015
    • 671
    ft 4822
    I know , i know ys old etc but the customer...
    I replaced developer , performed sp 4001, 4201 , 3106 but the image is too light . Any idea?
  • gkalman2004
    • 157
    Re: ft 4822
    A214 — Ricoh FT4822, Savin 9122DL
    Sorry i don't understand you performed what??
    3-106 Displays the initial VLP/VLG value determined by SP3-105.
    4-001 Exposure Lamp Voltage Adjustment
    4-002 Exposure Lamp Voltage Display
    4-201 Auto ADS Gain Adjustment
    When you change developer
    y107r
    -you must do TD initial settings with 2-214 and start key (machine will work 2-3 minutes).
    y twice
    -you must do twice Compulsory toner supply with 2-207 and start key (machnine first will work 30 seconds after and you repet once again)
    y key three times to exit SP mode
    • bob marley
      • Jan 2012
      • 1339
      Re: ft 4822
      sp 2-214 (TD Sensor initial setting)
      2-207 ( Forced toner supply)
      2-001 (Drum charge voltage adjustment ) 0 - 32 Default: 16
      2-003 (Drum charge Voltage adjustment) 0 - 32 Default: 16
      4-001 (Exposure lamp voltage adjustment) 50.0 - 75.0 V default = 63 V
      4-008 (Vertical magnification adjustment ) 0 - 32 V default = 16
      also perform sp 3-001 (ID sensor initial setting)
      Live for yourself and you will live in vain. Live for others, and you will live again
