Broken Fuser gears 2075- MP 8000
  • Codex
    • May 2008
    • 704
    Re: Broken Fuser gears 2075- MP 8000
    I don't know what happens to ricoh...but since a few years they produce very bad products or parts....the mp 5000 for example....that haves the same problems.as the Aficio 450.....
    Inviato dal mio GT-I9300 utilizzando Tapatalk
    Memento Audere Semper
    • Stormhammer
      • Mar 2016
      • 150
      Just wait until you have to take apart a 201 or 301.
        • 37490
        Keep the fusing unit properly maintained and you will have far less problems. This includes replacing the hot and pressure roller bearings. Either that or keep them packed with silicon grease. If the bearings turn rough then they can cause the gear to break.
        • anothertech
          • 1769
          #19
          We used to have a lot of those gears breaking when we were trying to extend the life of the fuser parts beyond what Ricoh recommended. We learned that the fuser rebuild need to be done at the recommended intervals, 450k for the MP6002-7502-9002 series. The fuser kit PMD131450k for the 6002-7502 and PMD133450k for the 9002 has the bearings in it.
          • keithxxiii
            Just a tech
            • Nov 2014
            • 469
            #20
            yep, always had them with this series (MP5500, 8000, 6001)
            gears are broken.
            Aye! Cut the crap
            • Codex
              • May 2008
              • 704
              #21
              We have a lot of 201, i know what you mean
              • Cipher
                It's not easy being green
                • May 2006
                • 1309
                #22
                I've had a few break.
                The part numbers have changed a couple of times now.
                The most recent part number change is:
                AB012233 - Hot Roller Gear
                (Old p/n: AB012062, B1404194)
                AE020242 - Pressure Roller
                (Old p/n: AE020209)
                Those two part changes cover the 00, 01, 02 and new 03 range (excluding the 90 ppm models).
                • anothertech
                  • 1769
                  #23
                  That new 03 model like kinda nice, they've made a few nice changes. Let's hope for best, we need a more reliable machine.
                  • lixx
                    • Sep 2016
                    • 6
                    #24
                    Replace the AE01 1117 and replace it.
                    The quality of new parts is very poor
                    • Qball
                      • Jun 2013
                      • 127
                      #25
                      I make it a habit to replace the gear every time I PM the fuser. I wish they came in the kit.
                      Sent from my SM-G900V using Tapatalk
                      • Lagonda
                        • Aug 2008
                        • 1649
                        #26
                        We fit a new gear every time we fit a new hot roller as there was a high incidence of the gear giving up the ghost with in a week of a new H/R being fitted.
                        • fireater
                          Repair God? not quite
                          • Apr 2006
                          • 253
                          #27
                          • so which gear is better the AB012233? or the AB01 2316?
                          • the AB012316 is from the mp6002 parts guide but precision roller shows it fits much older models.
                          • the AB012233 on precision roller shows it fits new models including mp6002.
                          • which gear is newer (supposed to be better longer lasting?)
                          • makes me confused
                          I fix copiers ...Well Sorta
                            • makes me confused
                            this thread is over 2 years old...
                            • guitar9199
                              • Sep 2016
                              • 1100
                              #29
                              I just rebuilt a 301 fuser on Monday... That was LOTS of "No Fun"!
                              • anothertech
                                • 1769
                                #30
                                It does not matter how old this thread is, the question is, what gear is the newest/most reliable? I'd like to know also, as they are still failing?
