Broken Fuser gears 2075- MP 8000
Re: Broken Fuser gears 2075- MP 8000
plastic is plastic,so it is meant to be the weak link..and crack,break etc..........'I like that they go honestly,a very easy service $$$$call and if it happens a few months later i end up popping in a new pressure roller as they cause "bounce" from all the flat spots..Comment
Hy
Did someone had problems with broken fuser gears on this series? I experienced a lot of broken gears during the year...i know ricoh changed the material , earlier gears was yellow...now they are grey...but the problem is the same....they break very easily. Yesterday i cleaned a machine...i made a print of the counter before i start to disassemble everything. ..then...after cleaning i made another counter to have a kind of "then and now"..and the machine jams in the fuser....gear broken...
Inviato dal mio GT-I9300 utilizzando Tapatalk
hello, this is one of the most classic problems on that machine, when you rebuild the fuser, or change the gear, I suggest you also replace the bushings of the fuser roller, because by consuming they work the fuser roller with an oscillating rolling effect, which makes sting the gear teeth accelerating the break when the material is cooked"I'll be back"Comment
hello, this is one of the most classic problems on that machine, when you rebuild the fuser, or change the gear, I suggest you also replace the bushings of the fuser roller, because by consuming they work the fuser roller with an oscillating rolling effect, which makes sting the gear teeth accelerating the break when the material is cookedComment
They were redesigned for the MP6002 and upwards.
You asked and you have your answer.
YES they redesigned the gear but you can't use it on an old clunker like a 2075 or an 8000.
And to answer your next question yes...they do still break,just not as frequentlyComment
It kinda DOES matter considering the new style fuser gear you can't use for those older fusers.
- so which gear is better the AB012233? or the AB01 2316?
- the AB012316 is from the mp6002 parts guide but precision roller shows it fits much older models.
- the AB012233 on precision roller shows it fits new models including mp6002.
- which gear is newer (supposed to be better longer lasting?)
- makes me confused
You are lucky,we have, together with brand new models, some old Aficio 1060/2075....Memento Audere SemperComment
