Im trying to connect a e-7000 to Aficio 3260C, but the machine does not ''see'' the Fiery. Replaced the connection cable, and reinstaled system software. The machine works fine with printer card. How much RAM needs Fiery to operate normaly? What Im missing? Thanks...
Fiery e-7000
1. Remove the I/F slot cover [A] ofSlot C [C] (this is the slot for the external controller) (! x 2).
2. Touch a metal surface to remove static charge from your hands before you touch the extension card.
3. Insert the extension card [B] into Slot C [C] and fasten it with the screws. (x 2).
NOTE:Make sure that the extension card is inserted straight and firmly.Connect the interface cable as follows:
− .Copier Side. [D]:
Connect this to the extension card and fasten the screws.
−.Controller Side. [E]:
Connect this to the video interface on the rear of the E-7000.
NOTE:If the interface cable is connected in the opposite direction, the copier engine will fail to communicate with the controller.
5. Connect the appropriate AC power cord [F] to the power connector at the back of the E-7000.
6. On the operation panel of the copier, remove the Slot Cover [A] and discard it.
7. Install the base key top [B] and Fierydriven key top [C] in the position indicated in the illustration. Use the correct keytops, as shown in the table below.
1. Connect the power cord of the copier to a power outlet and switch on the copier
main power.NOTE:1) The copier must be turned on before you turn the E-7000 on.
2) Make sure that all firmware modules for the copier are updated to
the newest versions. If they are not, update them before you turn on
the E-7000.
(☛ Copier Service Manual)
2. Turn the power switch on the E-7000 back panel to ON.
3. Allow startup to proceed without interruption, while you watch the diagnostic
LEDs on the back panel of the E-7000.
4. When the diagnostic LEDs show .00., go to the copier operation panel and
press the Fierydriven key. .Please wait. may be shown on the copier operation
panel.
5. The language selection screen is shown. (If this screen is not shown, then
press the Fierydriven key again.)
Select the desired language with the down arrow .$. key and up arrow .#.
key, and touch .OK..
NOTE:1) After you have selected a language, you cannot change the
language unless you do .Factory Defaults (☛ 4.3). or re-install the
system software.
2) The default settings for the E-7000 depends on the language
selection as follows:
Selected Language & Market Region
English - US English . UK/Dutch / Spanish/
Italian /German/French
PS Setting Default Paper SizesUS Metric
If you selected .English. at the language
selection screen, you are prompted to
select the market region. Select either
.US. or .UK. with the down arrow .$.
key and up arrow .#. key, then touch
.OK..
6. .Please wait.. will be indicated on
the Fiery menu screen, then the Fiery
menu screen will disappear from the
operation panel.
7. Wait for a moment, then press theFierydrivenkey again on the
operation panel. The Setup main
menu will appear on the Fiery menu screen.
NOTE:The E-7000 setup options should be configured later by the site
administrator. However, during the installation, a field technician must
check that the E-7000 controller works correctly with the default
configuration.
Therefore, the next steps show the steps for minimum configuration.
8. .Enter Password. message will appear.
Enter the default administrator password: .Fiery.1..
9. Touch the keys in the following order, to configure the minimum setup.
1) .Server Setup. key
2) .Main Menu/Cancel. key
3) (When you see .Save Changes for Server Setup / YES.)
.OK. key
4) .Network Setup. key
5) .Exit Network. key
6) (When you see .Save Changes for Server Setup/ YES.)
.OK. key
7) .Printer Setup. key
8) .Main Menu/Cancel. key
9) (When you see .Save Changes for Printer Setup / YES.)
.OK. key
NOTE:If you need to specify the system date and time, enter the Server Setup
menu and set them.
10. Select .Exit Setup..
11. The system will reboot. TheFierydriven
key will have no effect until after the
system reboots. To confirm that the
reboot was successful, press theFierydrivenkey. The Fiery Menu
screen will appear on the operation
panel of the copier.
12. Attach the Fiery Decal [A] to the copier
front cover.
the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed. -
Originally posted by batThanks for your reply but, I have the manual, and already tried everything from It. After turning main switch on and pressing Fierydriven buton "Please wait" is far I get.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
I have one and one only e-7000 fiery, and have recently had the same problem. In fact it woul say "Please Wait" and the customer could still print 1 & 2 page jobs to the copier, but it would always stay on the "Please Wait" screen.
If you have acces to the Ricoh TSC site you can download the fiery firmware. Go to the the AF 3260C colour copier "Tool Box" and you will find the e-7000 firmware tab there. You want to download the zip file eoz_chopin_fi_1.1.0. You will need to extract the folder with the same name and from that folder click on "Installer". You will need an Ethernet cable; the fiery download instructions at this point are very good and easy to follow.
The download takes quite awhile. Be sure to print the config page first because there are a lot of parameters to re-enter. Hope this works for you; I had no problems once I reloaded the fiery firmware!Comment
GOD_of_Repair
GOD_of_Repair
