MP 2550 PCU
  • tinfox
    • 317
    MP 2550 PCU
    I rebuilt a pcu and I'm getting ghosting spots around the edges of blacks. I've attached a sample.
    Thanks in advance!
  • LNorris
    • Sep 2008
    • 645
    Re: MP 2550 PCU
    what parts did you replace in the pcu rebuild?
    • tinfox
      • 317
      Re: MP 2550 PCU
      Drum, Drum blade, charge roller
      • LNorris
        • Sep 2008
        • 645
        Re: MP 2550 PCU
        did you replace developer? how many copies on it?
        did you check print before it hits the fuser?
        • tinfox
          • 317
          Re: MP 2550 PCU
          I tried a different pcu in the machine and it worked fine. Also I took the rebuild to another machine and it left the dots.
          I'm not sure how many copies are on the dev, but the blacks looks good.
          • copier tech
            • 8188
            Re: MP 2550 PCU
            If you have another good PCDU swap that dev unit with your rebuilt drum.
            • tinfox
              • 317
              Re: MP 2550 PCU
              Unfortunately that's the only one I have. Its been sitting in the warehouse for a couple of years and I thought I'd give rebuilding one a shot. I'll have to wait until I get another I suppose.
              I thought maybe this was a common problem with rebuilding...
                • 37553
                Re: MP 2550 PCU
                If it has been sitting in a warehouse for a couple of years, replace the developer. If you don't want to spend the money, try running about 200 to 300 double sided checkered flags, in sets of 10. This will agitate the developer, purge old toner and adjust the toner density level as detected by the image density sensor.
                • copyaction
                  • Oct 2007
                  • 991
                  Re: MP 2550 PCU
                  Start with new Developer
                  • tinfox
                    • 317
                    Re: MP 2550 PCU
                    Okay I'll give it a shot
                    • tinfox
                      • 317
                      Re: MP 2550 PCU
                      So I ran about 100 or so legal and it worked! The copies looked perfect now :-)
                      Thanks!
                      • sandmanmac
                        • 3983
                        Re: MP 2550 PCU
                        So you didn't rebuild the PCU. Why cut a corner like skipping Dev? It's inexpensive, and part of the PROCESS
                        EDIT: I hadn't read your final post before posting my thoughts.
                        Glad it sorted itself out, but when you take shortcuts to save a few $$, strange things can happen. Now it'll probably need a dev change before the drum wears out. Just saying.....
                        • Polarbear
                          • Feb 2012
                          • 1070
                          Re: MP 2550 PCU
                          Thanks!
                          Just as a side note, most newer machines have an sp called "Developer mixing" or similar.
                          This just agitates the developer by circulating it around the developer tank area without adding toner. It is good when a pcu/machine has been standing for quite some time without having been used. It brings back the triboelectric charge that should be in the developer for it to work properly.
                          Using this function gets rid of spotty copies most of the time. You could also do about 2 or 3 smc reports afterwards to improve the CQ.
                          Press the GREEN button!!
                          • sturmtrooper
                            Copier Combobulator
                            • May 2016
                            • 587
                            Re: MP 2550 PCU
                            Even some machines I would consider older do as well. I think the machine also checks sensor output as well but not positive.
                            • logrady2331
                              • Feb 2011
                              • 301
                              Re: MP 2550 PCU
                              Type 1027 PCU. That is all.....
