Mp6000 jams
  • tolede
    • Jun 2025
    Mp6000 jams
    First let me state that I know nearly nothing about this model. The paper is accordion jamming as it leaves the fuser. The next assembly does not appear to be activating. I cleaned what looked like sensors but it made no difference. Any insight on this problem?
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: Mp6000 jams
    Does it do this all the time? Only when duplexing? Does it do it when duplexing but only after the paper goes to exit the machine on the second pass? Does this machine have a finisher or just an output tray?
    If it has a finisher try removing that and see if it still jams. Could be jamming at finisher entrance.
    • Stormhammer
      • 150
      Re: Mp6000 jams
      What jam codes is the machine issuing? Also, I would try output tests on the fusing exit and paper exit motors.
      • Stormhammer
        • 150
        Re: Mp6000 jams
        This machine has TSB about there being a manufacturer defect on the duplex junction gate that causes trailing edge damage to pages which can cause it to jam as well. There is a new part number for the junction gate.
        • Mark Bbb
          • Jun 2012
          • 1662
          Re: Mp6000 jams
          If you are not familiar on this machine, you will end up with a unsatisfied customer.
          At least, get a training, somewhere.
