4001SP - Possible power issue
  • Stormhammer
    • 150
    I have a 4001 that is down and exhibiting some strange issues. It had an engine startup SC code so I swapped the engine board and now the machine will not even power on. All harnesses are correctly and firmly in place. I believe this machine has suffered some sort of electrical damage on reflection. The outlet that it is plugged into is scorched. I have the PSU on order but I was wondering what anyone else thought on the matter.
  • tnelson
    • Aug 2016
    • 21
    Re: 4001SP - Possible power issue
    by engine board do you mean the bicu? if so did you remember to swap the little eprom chip. if you didn't that may explain your issue.
      • 37533
      Can you tell us t he exact service codes you are getting?
      • Stormhammer
        • 150
        I believe the original SC code was 630. The manual described a late engine response or no engine response on startup.
        • Stormhammer
          • 150
          The PSU was the issue. The customer admitted to plugging the machine into a known faulty outlet. I metered the outlet and it's nowhere near stable. Some fuses were likely blown on the board, but the old board looked like it had some track damage. I didn't want to fuss with it and they're paying for it anyway.
          • TonerMunkeh
            Professional Moron
            • 3865
            Aaaand dear customer, here is a very large bill
            Hit it.
