Ricoh sp3510sf (error initializing)
  • omorales
    • Mar 2015
    • 86
    Hello friends wanted to know if someone had this problem.
    When the equipment is turned on, the screen (INITIALIZING) crashes.
    The team has no HDD.
    Nor can enter SP mode.
  • totoro
    • 568
    Re: Ricoh sp3510sf (error initializing)
    Not sure I understand. You're not trying to book the printer up with all the connectors unplugged are you?
    Totoro
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      Normally an result of incorrect engine firmware flash.
      Either way you are probably looking at PCB replacement.
      • Imprestik
        • Aug 2012
        • 297
        I have had this multiple times.
        I have replaced engine boards and it still come back weeks later
        To save yourself a lot of money just reflash the firmware via USB cable, it will get you up and running
          • 37529
          Unless it is a cratered board or a cratered firmware load, which in effect craters the board. If it will not let you load firmware, the board is cratered.
          • Iowatech
            Not a service manager
            • 3930
            For what it is worth, the last picture showed a number of disconnected connectors.
            Could that have something to do with this? Sorry I haven't worked on anything that new. But on the older machines, I have left connectors disconnected like a dummy and ran into something similar to this.
            • Mark Bbb
              • Jun 2012
              • 1662
              Well, I presume this photo has been taken before he plugged ALL the connectors back to there PROPER place...
              Or would he not?
              It's worth asking...
              Anyway, I haven't seen this trouble, because we don't have this type of machine in our field..., sorry.
