Hello Everyone. Hope All of you are having a nice day/night.
I don't know if this is the right seccion, if is not. Please tell me and I will moved (if i can, of course).
Today, I want to share my experience with a machine. A few days ago, a machine consistently showed me the codes SC390 and SC392. I changes everything (Developer, ID Sensor, TD Sensor, Drum, OPC Unit, Main Board.. etc, etc) It got me CRAZY!. I looked for information and help everywhere with no success. But thanks to the manuals and a little bit of logic I finally find the solution (or posible solution, it might not work everytime. I think).
So, first of all the manual said this:
Simple, Isn't it?. Well, think again... Is not always simple, believe me. As i'm ready said, I changed everything and tried everything with no succes. So, I read the manual many, many times till I find a work around.
The tone supply process is this: The machine constantly check the TD Sensor Value (Vt/Vts) and compare with the References Value (Vref), if the Vt/Vts value is higher than the Vref. the machine initiate the supply toner process. If the Vref value is higher than the Vt/Vts, the machine doesn't start the process. In my case, the machine showed me this values Vt/Vts 0.60/1.10 or below and Vref 2.50 (normal values). The quality was horrible. in some cases almost blank copy.
So, whats the solution?. This is the solution...
I found this SP Codes:
2929 - Vref Adjusment
2929 1 Upper Limit
Adjusts the upper limit for Vref. [0.00 ~ 5.00 / 3.10 / 0.01 V/step]
2921 2 Lower Limit
Adjusts the lower limit for Vref. [0.00 ~ 5.00 / 1.40 / 0.01 V/step]
As i'm ready explain. If the Vt/Vts value is higher than Vref Value the machine starts the supply process. With this code you can stablish an specific Vref value. In my case, when the Vt/Vts reach 1.10 or higher the quality go down considerably. So, I put my own values for the Vref Lower 0.50 and Upper 1.00. and this solved the problem. The machine start the process normaly.
This is a simple solution and works really well. This can be used in this models - 2027/2022/2550/3010/161/2020/1600/MP2000/1515
I Hope this information help somebody in the future
. Sorry if i talk too much, I wanted to explain as much as possible.
PS: As a final note, i want to say this: Sorry for my english, I'm still learning if you see some errors in my gramma. Now you know why
Code
390
Description
TD sensor error
The TD sensor outputs less than 0.5V or more than 4.0V 10 times consecutively during copying.
CausesCode
392
DescriptionCauses
390
Description
TD sensor error
CausesCode
392
DescriptionCauses
2929 1 Upper Limit
2921 2 Lower Limit
