04 Range - Special Service
  • MBZ6301
    • Aug 2016
    • 42
    Hi all,
    Recently we've got our hands on a bunch of colour 04 machines, and for the most part we're figuring things out. One head scratcher however is entering SSP, specifically for locking the scanner unit for the sake of transit. With the newer screens we're stumped figuring this out..
    No doubts it'll be the most obvious thing ever. Cheers
  • mikedci
    • Jul 2010
    • 227
    Re: 04 Range - Special Service
    same as before but use the EX3 button in place of the #.
    SOPSTUFF.pdf
    • MBZ6301
      • Aug 2016
      • 42
      [ATTACH]34618[/ATTACH]
      You're a star, thank you. Can't believe I never thought about it to be honest
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        I didn't know this too, many thanks.
        • anothertech
          • 1771
          Originally posted by MBZ6301
          Hi all,
          Please tell me more about locking the scanner for transit.
          • MBZ6301
            • Aug 2016
            • 42
            It mentions it in the installation part of the service manual, but basically when you receive the machine there are two locking pins holding the scanner carriage in place. This stops the unit moving when it's being moved in transport or being lifted at an angle. At a guess the new type of unit are heavier and as such are easier to damage through movement.
            IIRC the sp is 4-806-001
            Once you've used the code the unit moves slightly. Don't try to scan after doing this, you'll crash the machine on the current firmware
            • sturmtrooper
              Copier Combobulator
              • May 2016
              • 587
              I think that code only moves the scanner out from under the ADF slit glass so that dust won't fall on the optics while the machine is being moved.
              • Itanic
                • Dec 2014
                • 59
                Oh dear...I installed two MPC4504's last week and thought it was a typo in the manual. Couldn't find SP4-806-001 in SP.. Just transported without the lock's installed..
                • Zeldaman
                  • Mar 2011
                  • 946
                  Hi there!
                  Our company transported now 10 of this new boxes without the lockpins & nothing bad happens.
                  Greetings...
                  • sturmtrooper
                    Copier Combobulator
                    • May 2016
                    • 587
                    It might be in the scanner SP menu. I've transported copiers 60-70 miles without the scanner pins and it doesn't seem to matter. I think if you smacked the machine hard enough to matter it would break something.
                    • Barry Benford
                      • Feb 2013
                      • 5
                      Hi,
                      To move the scan carriage back to it's transport position.
                      Enter service mode reset + 143 + c twice
                      Enter 4804 and execute
                      Enter 4806 and execute
